If you use a Li-ION charger , you need to have a led on it ,and this led charge from red to green when bat is full.
The led is locate on the charger and not on our PCB.
So you can directly connect your battery to the charger.
Normal working and cabling :
Charger 29.4V 2A or more is used to power the sender and station (charger led is green).
When mower is in station the POWER PCB yellow led indicate the Voltage on mower charging pin and can start the charging if needed (see setting battery) (charger led become red).
