Today I did some tests with ultrasonic sensors on the Raspberry Pi using a Python script.
I tested the waterproofed JSN-SR04 as well as the HC- SR04. My findings:
The HC SR-04 is cheaper and more accurate than the slightly more expensive JSN-SR04. This sensor can only measure the shortest distance of 20cm. It doesn't provide any valid if the distance is shorter. The HC SR-04 measures minimum distances to 3 cm very reliably. Both sensors deliver valid values up to a distance of 250cm. However, strong reflections occur in the room, which distorts the measurement results. This would still have to be tested outdoors. A disadvantage is that you need 4 GPIOs for 2 sensors. I haven't found a script that uses only one trigger signal yet.
So if I change the ToFs in Ultrasonics Sensors I will use the HC- SR04. But I see in the moment not a great advantage to the VL530X ToF.
Has anybody a solution on Raspberry Pi for 2 Sensors with only one Trigger Signal?
May be this can be a solution
 while True:
       GPIO.output(TRIG, True)
       time.sleep(0.00001)
       GPIO.output(TRIG, False)
       while GPIO.input(ECHO_left)==0:
          pulse_start = time.time()
       while GPIO.input(ECHO_left)==1:
          pulse_end = time.time()
       pulse_duration = pulse_end - pulse_start
       distance_left = pulse_duration * 17150
       distance_left = round(distance+1.15, 2)
       time.sleep(0.00001)
       while GPIO.input(ECHO_right)==0:
       while GPIO.input(ECHO_right)==1:
       distance_right = pulse_duration * 17150
       distance_right = round(distance_right+1.15, 2)
       print("Left: ",distance_left,"cm \t Right: ",distance_right,"cm" )
       time.sleep(0.2)
i Have exactly the same result in my side .
HC-SR04 is perfect for short detection, so put it in direct front of mower and read it each 500 ms and normally mower never hit object.
JSN-SR04 are OK between 50 cm and 1.5 meter but no so reliable than HC-SR04 at short distance.
For 1 trigger signal i never test.
Teensy is here to have more free pin and i don't know if MCP23017 is fast enough for sonar use.:ROFLMAO:
Thanks for sharing your results with me. I thought JSN is a good alternative for the ToF, but unfortunately no.
During the winter months I will rebuild my first Mower with the actual drivers and SW. for that I have to print some parts. In this mower (Project name "Hybrid") I wil use the SR04. And its easy to transfer the distance Data form the teensy together with the perimeter Data via i2C to the pi.
So I will do that in this way. Nice weekend!
What is your experience with bushes, flowers and shrubs?
The reflection is not as good as a smooth surface like a wall or something similar
They are detected, but not all the time in my test, so not a 100% reliable solution.
I only test detection between 40 and 90 cm with JSN and HC sonar , so certainly sensor at front of mower work better.
Perimeter wire is more secure for flower.
Do you have any experience with disruptions on the I2C bus in the ArdoMower projects?
The only reason I would replace the ToFs with SR04 on my Test Mower is to avoid sensor malfunctions
due to I2C interference. Malfunctions very rarely occur. The sensor values usually only freeze
for one sensor. If I restart the script it works propper again. But there is no way to detect that.
Because if its freeze e.g. 200cm you don't know if there is an obstacle or not. If its freeze e.g. 76cm
and he drive forward, and the distance not change, then it make sense to restart the Script.
But I recognized this only at my MINI Test Mower Model
Heute habe ich bei meinem MINI Test Mower Model die VL53L0X ToF Sensoren gegen VL53L1X ToFs ausgetauscht.
Ich hatte diese Sensoren noch in meiner Bastelkiste gefunden und wollte die schon seit langem mal testen. Was soll ich sagen, ich bin begeistert,
In freiem Gelände konnte ich die noch nicht testen, aber in meinem Hobby Zimmer stellen die die VL53L0X ToFs in den Schatten. Die ich vorher hatte waren bis 2m distance angegeben und schafften 127cm. Darüber hinaus wurde es schwierig. Gut für das Ausweichen des Mowers ist da Platz genug. Aber mit ToF400C-VL53L1 habe ich eben im Flur ohne Probleme 376cm Entfernung messen können. Da war ich schon beeindruckt. Also qualitativ doch besser als die VL53L0X für ca. 3,50€. Für die ToF400C-VL53L1 mit vorgesetzter Schutzlinse habe ich bei Ebay ca. 7€ pro Stück bezahlt. Ich betreibe sie mit dem TCA9548 am I2C Bus.
Für meinen großen Alko Mäher den ich im Winter umrüste, stelle ich mir diese an der Front vor, jeweils rechts und links und ebenfalls an den Seiten, um vor einer Drehung zu schauen ob an der jeweiligen Seite genügend Platz ist. Der ALKO Mäher ist gute 60cm lang und braucht zum Drehen schon ein wenig Platz.
Hallo
heute habe ich in meine Android BT-App eine Kompass Rose eingebaut.
Sie zeigt mir die aktuelle Fahrtrichtung vom QMC5883L an. Der Kompasswert wird alle 250ms an die App übertragen. Batteriestatus und Mähmotor Anzeige werden sekündlich aktualisiert. Der Mittelpunkt der Rompass Rose fungiert nach wie vor als Joystick für die RC Steuerung.
Im Moment ist es bei uns aber so nass auf dem Rasen, dass ich da leider nicht fahren kann.
Also muss ich vielleicht noch bei @Fürst Ruprecht in die Lehre gehen und auf Allrad umstellen. Das kommt sicher noch wenn ich mein BoByCar aufrüste. Der receiver Code und den Code für die Android HandyApp findet ihr hier auf github
Ich habe sie mit Android Studio geschrieben und ist ab API 28 lauffähig.
Vielleicht finde ich noch einen Ziffern Kreis um auch die YAW Werte darstellen zu können.
Your Feedback is welcome
