Are you sure you have a compass inside and not a simple IMU with Gyroscope and Accelerometer ???but the normal compass inside may be disrupted
Yes it's the goal.So every time when the mower cross the ribbon the qmc will show wrong blaues i assume
Moin Ulli,Yes it is easy. I use opto-coppler because I made the experience, that several levelshifter have several characteristicas and the Pi is sometimes picky. So far I remember right end of last year, I tested out, that on the break Pin of the ZS Board, there are 5 Volt. So the Pi is not happy with that.
The HALL signal is 5 Volt, as you know you can manage this with 2 restiors. But I started my professional carrer as a Radio & TV technician and I love Optocoppler and I have I'm honest around 100 PC817 in a box. So they will be used. But it is really true. I used 3 different Levelshifters and an arduiono works propper with the levelshifter, the pi had problems. This is the reason why I designed this smart PCB wich fits exactly in Front of the ZS Boards. But I forgot the Pull-up for GPIO 12
Hallo @Sascha , @EinEinfach hier ist https://github.com/ullisun/RopiLawnMow/blob/main/MotorCal/Scheamtic.pdfMoin Ulli,
ist der Schaltplan auf Github aktuell, oder musste da etwas dran geändert werden?
Ich sitze gerade an EinEinfach seine PCB und überlege, das gleich mit einzufügen.
I also test this kind of sensor, but always fail outdoor in full sun.ToF VL53L0X
Thanks @Richtel and @Bernard for your comments. I am quite sure that I fixed the problem. I am using now a different library and since this afternoon i made a lot of tests and all 3 sensors delivers the correct distance during the timeHello, I've browsed around a bit about possible problems and perhaps found a small solution...
VL53L0X Time-of-Flight (ToF) Laser Abstandssensor - [Teil 1]
Einführung In diesem Beitrag möchte ich Ihnen den Abstandssensor VL53L0X vorstellen. Ich werde Ihnen zeigen, welche Bibliotheken in der Arduino IDE zur Verfügung stehen und wie Sie den Sensor an einen ESP8266 anschließen. Außerdem bauen wir einen einfachen akustischen Abstandswarner, den sie...www.az-delivery.de
