D18,D19 are Tx/Rx-Pins in your PDF (github, Ardumower_teensy_pro), and D20,D21 are SDA/SCL-Pins.
At the moment, i do not use Sense feedback of the two frontmotors.
I have already made a plan for the pin assignment. The pins of the Teensy are not enough so I wanted to make a port expansion. I asked you for the complete circuit to see what you do with the esp32.
One way to reduce the pin count would be to replace the ultrasonic sensors with TOF sensors with i2c.
Since i use the stepper motor for steering, the signals from the ultrasonic sensors are very poor. I did not have this problem when using servos. One reason is also that the control of the stepper is in the back and the stepper in the front of the mower.
Maybe you can post the pinout of Teensy and esp32 in github, then I can see how far it fits for me.
