First Design Perimeter Sender
Den habe ich leider nicht in KiCad aber dafür den L7805CV, sollte die gleiche Funktion haben.
Dann baue ich den da noch ein und dann die Beschriftung der Pins noch und dann kann ich hoffentlich bestellen.
Ein paar Leute warten ja schon auf ihre Platinen.
Why did you want to add a 5V regulator ,The L298N driver generate the 5V.
The fixed voltage regulator is optional, you can also connect the 5V from the motor driver as normal.
Here are a few more pictures. Now i must route them and then it should be ready.
These are my last boards for now, I think they are OK and fulfil their functions.
So unfortunately it took a little longer, but I have now added the
the traces and finished the board. Interactive BOM file is also included again.
Files are on Github
That seems too difficult for me. I hope that someone deals with the firmware and releases a new version for this board.
Do you have a little time?
I'll try to solder my transmitter PCB on Friday so that I can test and adapt the code.
But I can't promise that I'll be able to do it.
Of course, i've a little time. I have ordered a batch of PCB. I'll think they will arrive in about 2 weeks. Then i could try It too.
