You need to test the start button of the MOW800 ,if it is close when you don't push it : you need to set this value to true.Ah ok das kannst du in der mower.h ändern:
Code:#define START_BUTTON_IS_NC false //if button is normaly closed
Die und die mower.cpp musst du mal durchgehen.
Please post a photo of the charge PCB including INA226I've seen that the charge current ist about 8v with open contacts?!? Eventually a broken diode?
It's only OK if the mainPCB is not connected (No 3.3V on PinBatterySwitch).If J8 ist bridged, the power is on. If i leave it open, the power switches off... Is it ok?
Blue poti on driver is not set to 0 ?Der Motor dreht ohne PWM-Signal.
