Power_PCB_v100small_MOD for Landrumower / Teensy
RD123
Member
Based on:
Version for Landrumower and Teensy (different file in attachement).
To do:
-UNTESTED!!!!
-Replace components for LSCS versions to be SMT machine assembled.
Because the components stock can change in time in lcsc warehouse. The production file should really be done, before sending file for production:
The easy way is to assign lcsc components id in scheme (that are currently in stock). And use the Kicad plugin (using plugin manager) to generate all files:
Differences:
-one version rewired to be compatible with Landrumower scheme.
-repositioned mosfets/diodes for easy integration with heatsink:
-smaller PCB size (lower manufacturing costs).
Quote for PCB:
Power_PCB_v100small - 33.24 usd
Power_PCB_v100small_MOD - 5 usd
-added optional safety braking resistor circuit for BLDC driver especially for MOW motor.
It can be skipped if not necessary.
-added xt-30 connectors for high current.
-added holder for Car blade fuses. (That fuse can't be Polyfuse for safety reason).
Or External Panel Mount Fuse Holder
-Upgraded diodes for 100V. 45V is not enough.
-added diodes for switching Mosfets. In case of Mosfet failure, it should not fry Raspberry port.
Very good job.
2 remarks:
For INA226 , you use 1 I2c line ,maybe need some change on INA226 china PCB.
I see some SMD parts , Why not directly integrate the INA226 as SMD part ,so you can easily fix the I2C line adress and bus end resistor.
Also why 2 jumper in parallel for battery charge and TP1 TP2 on the same wire ?
Congratulation.
