Yes, unfortunately, they were all broken.
But protecting each individual slot is also a lot more diodes. Maybe it's enough to fuse the main PCB against 24V. I'll try to find a solution.
The capacitor should actually fit.
You can check the IRF9540N to see if you have continuity.
Bernard, you have the capacitors from the Marotronics shop?
Unfortunately they are sold out, I'll see if I can find them at Reichelt. But actually there shouldn't be any differences, the data is the same.
I have already had 3-4 PowerPCBs and the same thing with all of them. It must be due to some component.
